Нов Windows2000 драйвер, версия 5.52.010 за Matrox G400/G450...
г. 23:35 ч.
От Matrox обновиха Win2K драйвери си за видеокартите Millenium G400/MAX и Millenium G450. Новото в тази версия е:
  • DX Diag now reports AGP texturing is enabled.
  • Fixed no output of real media via DVD Max.
  • Fixed windows Roll up feature.
  • Fixed missing menu screens when running Softimage at 1280x1024x32bit.
  • Improved high CPU usage when DVDmax is enabled.
  • Fixed Pro/DESKTOP corruption resizing workspace when using objects defined from the object palette.
  • Fixed problem with X-plane not loading.
  • Fixed text corruption problem with Unigraphics V17.0.
  • Fixed Oni premature exit.
  • Сега нека да погледнем кои проблеми все още се "доизглаждат":
  • When running Java program used swing UI, you may see 'garbage' along mouse movement such as menu navigation.
  • Choppy playback of DVD titles on PAL TV.
  • Age of Empires 2 won't run in clone.
  • Maximizing LightWave Modeler window across two screens causes crash.
  • Some applications such as VB6 and VC++6 will appear on all your multi desktops.
  • You may see corruption running Directx apps with Flat Panels.
  • You may get a program error when you drag the Mplayer onto the 2nd head when in VirtualHead mode.
  • You may see a dialog box stating that it is currently trying to shut down IE. If this happens, you will have to click on End Now button to restart your system.
  • TV out adjustment for G400 is not functional.
  • Viewports will not refresh in Messiah. Temporary workaround - Close Lightwave, set desktop to 24 bit color. Start Lightwave. Start Messiah and then switch desktop back to 32 bit.
  • Нормалният вариант на драйвера можете да изтеглите директно оттук, а за e-DualHead версията ще трябва да се регистрирате (ако все още не сте го направили, естествено).
    Споделете тази новина:
    Подобни новини
    SetCombG.com новини
    Още Новини
