GeForce FAQ, версия 18.6...
г. 23:37 ч.
Christopher "Не сега сега скъпа, обновявам често задаваните въпроси" Hill актуализира за пореден път неофициалният GeForce FAQ. Новото този път е:
  • Added 6.23 and 12.00 links, 7.58 MVP3 note, 6.26+ PowerDVD 2.55 note and 10.80 WindowFX note to drivers questions.
  • Added 'Win9x notes also apply' note to Win2K and NT4 driver questions.
  • Changed all drivers links from an IP to http://www.gamers-ammo.com.
  • Added Windows 2000 / 75hz problem fix to 'How can I manually set refresh rates and force the refresh rate above 60hz?' question.
  • Added 133mhz memory speed tip to 'I have a VIA chipset based motherboard and I can't get AGP4X to work without causing instability. How can I fix it?' question.
  • Added NVCleaner information and download link to 'How can I completely uninstall old NVIDIA GeForce or Creative Labs Annihilator drivers?' question.
  • Added VIA / Athlon troubleshooting guide link to 'My GeForce keeps on locking up or drops me back to the desktop during 3D applications. How can I fix it?' question.
  • Corrected 5.xx, 7.xx and 10.xx DX8 and palletised textures support information to 'What is the difference between the 3.xx, 5.xx, 6.xx, 7.xx and 10.xx versions of the drivers?' question.
  • Added virtual memory tip to 'I get 'Out Of Memory' errors although I have plenty of RAM installed. How can I fix it?' question.
  • Renamed and added lots of tips to 'My 2D display is corrupted. How can I fix it?' question.
  • Added disable registry file links to 'How can I enable OpenGL hardware accelerated anti-aliased lines on a non-Quadro card?' question.
  • Renamed and added 7.58 tip to 'I have problems with my Super Socket 7 motherboard. How can I fix them?' question.
  • Corrected GeForce 256 memory speed to 166mhz in 'What different types of GeForce card are available and what are the differences between them?' question.
  • Changed command line in 'Shogun: Total War crashes to the desktop before the opening screens. How can I fix it?' question so that there are no error messages.
  • Added ASUS note to 'How can I get SMP working with Quake 3 Arena under Windows 2000?' question.
  • Reorganised 'How can I speed up Unreal Tournament on my GeForce?' question.
  • Ако имате проблем с вашата GeForce базирана видео карта то несъмнено решението на проблема ще намерите в GeForce FAQ.
    Споделете тази новина:
    Подобни новини
    SetCombG.com новини
    Още Новини
