R3DTweak, версия 2.2 ...
г. 18:43 ч.
R3DTweak е един от многото навъдили се напоследък туикъри за видеоконтролери на базата на ATi Radeon. Новото в тази версия е:
  • Added check to enable/disable all ATI tabs in the Rage3D Tweak taskbar utility.
  • The taskbar utility now lets you change profiles from the right-click menu on the icon.
  • Added Profile features (available from right-click menu on any custom profiles):
  • Shortcut option for profiles: Creates a shortcut on your desktop to any game or application you specify that automatically changes to the selected profile when running the specified app.
  • Save option for profiles: Save the tweak profile settings to a file instead of the actual registry settings (export saves the actual registry settings to a .reg file). Ultimately will help with porting profiles from one tweaker version to the next.
  • Added in game gamma modification support:
  • ALT-G = Increase game gamma.
  • ALT-SHIFT-G = Decrease game gamma.
  • ALT-SHIFT-CONTROL-G = Exit and Reset gamma.
  • Updated Resume Fix to reset overclocking settings:
  • Should work in all cases of a system resume now.
  • Does not yet work for basic monitor power save.
  • Cosmetic updates.
  • Minor bug fixes.
  • Програмката може да бъде свалена директно оттук. Официалния сайт на туикъра пък можете да посетите чрез този линк.
    Споделете тази новина:
    Подобни новини
    SetCombG.com новини
    Още Новини
