- Added 10.80 / SWAT3 note, 11.00 / X-tension fix, 12.10 / Win2K notes and 12.20 & 12.40 links to driver questions.
- Updated 'What different types of GeForce card are available and what are the differences between them? question for GeForce3.
- Added 'How can I enable and change the quality of anisotropic filtering?' question.
- Added 'How can I overclock in Linux?' question.
- Added 'I have problems with Diablo 2. How can I fix them?' question.
- Added 'How can I enable mipmapping in Rollcage Stage 2 on my GeForce3?' question.
- Added 'I have problems running SoftIce on my GeForce. How can I fix it?' question.
- Renamed and added 11.xx and 12.xx information to 'What is the difference between the 3.xx, 5.xx, 6.xx, 7.xx, 10.xx, 11.xx and 12.xx versions of the drivers?' question.
- Added 10.xx+ antialiasing options information including Quincunx to 'What do the different antialiasing options mean?' question.
- Added *lots* of new tips and renamed 'My PC won't POST (doesn't display anything when I switch it on) after I put my GeForce card in. How can I fix it?' question.
- Added monitor extension cable and monitor off tips to Win2K / 75hz section of 'How can I manually set refresh rates and force the refresh rate above 60hz?' question.
- Added Start button and dodgy card tips to 'My 2D display is corrupted. How can I fix it?' question.
- Added 'Enhanced CPU instruction sets' tip to 'Games stutter with my GeForce. How can I fix it?' question.
- Added Windows 2000 registry files to 'How can I force AGP1X to be used instead of AGP2X or AGP4X?' and 'How can I enable or disable AGP Fast Writes?' questions.
- Added more settings to 'What are the recommended BIOS settings for a GeForce?' question.
- Added GeForce3 BIOS link to 'Where can I get the latest NVIDIA Flash BIOS and which should I use?' question.
- Added CAS4 tip to 'I have a VIA chipset based motherboard and I can't get AGP4X to work without causing instability. How can I fix it?' question.
- Added AGP aperture tip to 'I have problems with flickering, tearing or polygons in the wrong place in 3D applications. How can I fix it?' question.
- Clarified location of GTF / DMT setting in 'My 2D image quality is poor (fuzzy, ghosting, smeared bold text). How can I fix it?' question.
- Updated links to Wim's BIOS page.
- Removed dead link to the Overclockers Australia forums in 'I have a VIA chipset based motherboard and I can't get AGP4X to work without causing instability. How can I fix it?' question.
GeForce FAQ 18.8...
г. 22:19 ч. Кристиан ДимитровСподелете тази новина:
