GTU settings tab has a new function that saves current settings as default. Debug mode creates gtu_debug.txt which might help to detect GTU errors. Added debug mode, can be activated with command line switch /debug. The /all switch overclocking feature works with all NVidia cards now. The stereo settings under w2k are different from the w9x settings. Some w2k adapter detection errors have been found and fixed. A problem with the overclocking buttons has been solved. The W2k version now is exactly the same as W9x/ME. The Undo button now also works under NT/W2K. Fixed overclocking support in beta 8 and 9. Bugfix at: wscale16/24, fogtableenable, Def. OpenGL render quality. Bugfix the Color Correction tab - now it works under W9x/ME/2K.
GeForce Tweak Utility, версия 3.03...
г. 23:17 ч. Кристиан ДимитровСподелете тази новина:
