mIRC обновен....
г. 16:03 ч.
В речниците на мястото, където се мъдри думата 'чат' със сигурност ще намерите а името на не друг IRC Client, а именно това на mIRC. Та същата тази програма вчера бе обновена до версия 5.91. По традиция ще приложа и непълен списък на новостите в тази версия:
  • The flood protection has been improved with options to take your own ctcp's and 'whois on query' settings into account. You can even make Op status related commands (like /kick) to bypass the anti-flood queue.
  • Since IRC networks don't provide a consistent method of telling an IRC client the name of the network it's connected to, mIRC now supports the numeric 005 NETWORK=name token. Hope that helps?
  • When you have the "keep channel open" option enabled, mIRC now clears the nicklist if a channel window is open but not joined.
  • A "Blink icons" option is added to the Display dialog. With this option the switchbar icons of channel/query windows will blink if there's a message/highlight or flash event.
  • Notify no longer triggers on a nick change if nick has only changed case.
  • A $+(n1,...,nN) identifier that combines parameters has been added.
  • The notify options to show address and time are re-added.
  • The Hash commands are extended to allow storage of binary variables.
  • The variable types dispatch and unknown are added to $com(). These allow you to pass dispatch/unknown pointers as parameters in a $com() call, or to retrieve dispatch/unknown pointers from a $com() call, by reference.
  • You can now pause and resume a timer with the /timer -pr switches.
  • mIRC now waits 30 seconds before a re-connect attempt if the server says that you were throttled for connecting too fast.
Можете да свалите програмката директно оттук, а пък ако се нуждаете от повече информация за нея ще е най-добре да посетите нейният уебсайт.
Споделете тази новина:
Подобни новини
SetCombG.com новини
Още Новини
