RadeonTweaker, версия 1.1.94 (Development Release)...
г. 14:56 ч.
RadeonTweaker бе обновен за пореден път. Това е tweaker за видео карти от серията Radeon на ATi. Какво е новото:
  • Fixed a profile bug.
  • The win2k 60hz fix now allow the user to choose from 60hz, 75hz, 85hz, and 100hz.
  • Added several new icons.
  • Added a 'gnu/linux' section to the driver installation guide.
  • Added the ability to disable the extra programs from running at system startup.
  • Added the ability to choose local or global setups (i.e. global setup means every user on a machine will have the same clock settings, gamma settings, etc. local setup means settings are tailored on a per-user basis).
  • Added the ability to select which monitor you are using (needed to ensure the 60hz fix alters the right reg location).
  • All of the installer issues should be sorted out now.
  • Minor ui improvements.
  • FAQ update.
  • Added a 'tomb raider' profile.
За да го имате кликайте тук а за повече информация тук...
Споделете тази новина:
Подобни новини
SetCombG.com новини
Още Новини
