Mozilla браузер, версия 0.9.2...
г. 14:17 ч.
Около 2 седмици след последното актуализиране на интернет браузерът Mozilla се появи и версия 0.9.2. Ако не се сещате какво точно е Mozilla ще ви помогна - точно това е ядрото, на което е базиран Netscape 6.
Можете да си изтеглите Mozilla 0.9.2 във версии за различни операционни системи от тази страница или направо от FTP-то им...
UPDATE: Какво е новото:
  • Continued stability improvements with 25 top crash bugs fixed since 0.9.1. These bugs were fixed thanks to data generated by users running talkback builds.
  • New context sensitive help in preference dialogs and new help viewer content donated from the Netscape 6.1 PR1 release (which still needs to be Mozillafied). (Bug 46917)
  • On Windows, you can now permanently delete your Imported IE Favorites folder. (Bug 22642)
  • The preferences dialog now allows you to turn off animated gif images or set them to only animate once. (Bug 64831)
  • The View Source window has a new toolbar for common tasks like File, Edit and View. (Bug 63026)
  • There is a new turbo mode pref on Windows which allows you to "pre-load" Mozilla when you boot in order to reduce browser startup time. (Bug 84882)
  • You can click the lock icon to see security information about the current page.
  • Security UI and help is now fully integrated with the rest of the browser interface. If you are a developer, you can find more technical information about Mozilla 0.9.2 security features on the Personal Security Manager Project Page.
  • To get Mozilla to spew debugging messages to the console, enable verbose mode by adding the following line to prefs.js file in your profile: user_pref("browser.dom.window.dump.enabled", true);
  • The syntax for blocking pop-up windows has changed since Mozilla 0.9. To block pop-up windows, add this line to the prefs.js file in your Mozilla profile directory while Mozilla is not running: user_pref("capability.policy.default.Window.open", "noAccess");
  • If you want to allow specific sites to open new windows, add the line above and also these lines:
    user_pref("capability.policy.allowpopups.sites",
    "http://www.mozilla.org http://bugzilla.mozilla.org");
    user_pref("capability.policy.allowpopups.Window.open", "sameOrigin");
  • Споделете тази новина:
    Подобни новини
    SetCombG.com новини
    Още Новини
