KT7/KT7A BIOS 1.11.0402 ...
г. 01:15 ч.
Нов ъпдейт за BIOS-ите на KT7/KT7A дънни платки. Ето и някои бележки:
  • Based on beta BIOS KT7_3R.B01
  • Update BIOS code.
  • Enhance ISA PnP compatibility.
  • Enhance SCSI adapters compatibility.
  • Add 1400(133) Athlon support for KT7A/KT7A-RAID.
  • Add new option "1200 above" for high speed Athlons with 100FSB. KT7/KT7-RAID/KT7A/KT7A-RAID/KT7E only support 1.4G(100) Athlon with L1 bridges disconnected. Check L1 before you buy a CPU please!
  • For Creative SBLive 5.1 sound card users, you may try these options while experience sound quality issue. .PCI master read caching, default setting=Disabled .PCI master time-out, Default setting=1 Setting above options to Disabled/3 will lead to the same result with VIA Latency patch V0.14 and may help SB Live 5.1 sound issue. If the system experiences low performance after these settings, enable the "PCI master read caching" please.
  • Change HPT BIOS to 1.11.0402 for KT7-RAID/KT7A-RAID. This BIOS version is also for non RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
  • Enhance the high speed 133FSB Athlon stability for KT7A/KT7A-RAID.
  • Side effect: CPU temperature becomes higher, about 50 degree C while gets into Windows 2000 and ME.
  • Споделете тази новина:
    Подобни новини
    SetCombG.com новини
    Още Новини
