WinRAR 2.90, версия Beta 1...
г. 01:41 ч.
WinRAR, старият конкурент на WinACE бе обновен да версия 2.90 Бета 1. Какво е новото в нея:
  • Added extraction only support of BZIP2, JAR (Java ARchive) and ACE 2.0 formats.
  • Now it is possible to use full file paths such as d:\path\name in the exclude lists and -x switch when archiving. Earlier versions understood only relative file paths here.
  • New option "Append archive name to path" in the "Settings/Compression" dialog. It is used only if the default folder for extracted files is specified and it controls if the archive name is appended to the default folder name when constructing the destination path.
  • New 'E' parameter for -ag switch denotes a day of year. For example: rar a -agEEE backup.
  • To provide a reasonable tradeoff between compression and reliability, RAR resets solid statistics between volumes only if sufficient data (about 4 MB) had been processed since the last reset.
    - You may use two new switches to change this default behaviour. Switch -sv forces RAR to always reset statistics, regardless of volume size, when -sv- disables such reset at all times.
    - Switch -sv- supersedes -sd, though the latter is also recognized by RAR for compatibility purposes.
  • The choice "Never" is added to the file overwrite request displayed by console mode RAR. Style of console RAR requests is somewhat altered.
  • "Extract Here" item is added to archives context menu. You may use it to unpack archive contents to the current folder.
  • If you selected several archives in Explorer and then right clicked them, the context menu will include both archiving and extraction commands, so you may unpack all the archives at once.
    - The old group unpacking method, through dragging a group by the right mouse button to the destination folder, is also supported.
  • File selection is not cleared when a user cancels the archiving in WinRAR, so it is possible to repeat archiving without selecting files again.
  • File lists (@listfile parameters of the command line) may now contain comments preceeded by // characters.
  • Disks disabled in the system policy are not displayed in the toolbar and "Change drive" menu.
  • BUGFIX: Switches -y -inul did not disable some messages in GUI WinRAR;
  • BUGFIX: Sometimes WinRAR could display "Cannot create temporary file" error when opening a lot of archived files for a short time;
  • BUGFIX: Now RAR skips archived names like 'prn', which belong to devices reported by Windows 2000 as pipe. Names of character devices are skipped by both this and previous WinRAR versions.
  • Можете свободно да свалите и тествате тази бета версия.
    Споделете тази новина:
    Подобни новини
    SetCombG.com новини
    Още Новини
