Quintessential Player 3.30 Beta...
г. 23:03 ч.
Quintessential Player, любимият ми аудио плейър бе обновен до версия 3.30 Build 16, която би трябвало да водите като бета. Интерфейсът му ще зарадва любителите на красивото, но едва ли ще се хареса на тези с Pentium и AMD K5 базирани машини. Ето какво е обновено в последният build:
  • Fixed shuffle button as it was wacked.
  • Fixed when progress slider gets dragged out of range, time now goes back to current.
  • Fixed window focus problems, hotkeys being ignored bugs.
  • Fixed number showing up for genre sometimes in extended info.
  • Fixed OverlayText routine drawing too light for some TTFonts.
  • Fixed CD info editing / submitting fixes.
  • Fixed bug in reading Ogg Vorbis ICEcast streams.
  • Fixed potential WaveOut playback crash bug.
  • Fixed bug in dynamic loading of new plugins.
  • Updated /eject command line switch to take drive parameter.
  • Updated media icons have new look (thanks to Brian "Aer aquila").
  • Updated improved offline query caching in CDDB plugin.
  • Updated MP3 decoder (XAudio 3.2.9).
  • Updated Vorbis decoder (v1.0 RC1) - and split decoder/encoder into two plugins.
  • Updated skin downloader to tell of new vs updated skins, and indicate new skins.
  • Updated skinned border allows resize on all sides.
  • Updated mouse scroll wheel to change volume if not on other scrollable controls.
  • Updated 'load playlist' menu to be alpha sorted.
  • Updated failed-to-load files only shows one message at end of loading now.
  • Added /ejectall and /closeall command line switches.
  • Added 'Install QCD Skin' to skin rightclick explorer menus.
  • Added separate icons for playlist files.
  • Added skin icons in skin downloader, plus column reordering.
  • Added skin icons to skin browser tabs.
  • Added 'add menu' to play button right-click.
  • Added CD identifier to .PLS playlist files so playlist only applies to correct CD.
  • Added track time to playlist (option in trackbox right-click menu).
  • Added vis FPS counter to Preferences->Plugins.
  • Added skin extension accelerators (shift+1...4).
  • Added 'sort by track number' sort menu option.
  • Added improved 'Preferences->Media Loading' features.
  • Added 'start minimized' option to tray preferences.
  • Quintessential Player 3.30 Build 16 може да бъде свален с помощта на този линк.
    Споделете тази новина:
    Подобни новини
    SetCombG.com новини
    Още Новини
