Nero Burning Rom 5.5.10.7b
г. 20:09 ч.
Поредна нова версия на Неро-то.
Какво ново:
- Added several new recorders
- Nero Fast CD-Burning Plug-in for Windows Media Player 9 included
- Improved context sensitive help-header
- Nero Express window resizing enabled
Оправени бъгове:
- Fixed the bug which produced incompatible Video-DVDs not playable on some DVD-players
- Fixed an Audio CD problem which occurred with few recorders
- Fixed recorder speed display problem with some recorders
- Disabled CD-Text language combo box when no CD-Text is available for compilation type
- Fixed a problem which could occur in some cases with the UDF/ISO9660 bridge file system
- The correct language help files are called for all countries which use the same language
- Fixed problem when changing from Nero Express to Nero with enabled Nero Wizard
- Nero Express: Fixed a small problem on the string box disc name in Nero Express and Windows XP
Може да го изтеглите оттук или оттук | bg mirror (13390Kb)
Споделете тази новина:
Подобни новини
SetCombG.com новини
Още Новини
