Добре, добре... вече можете да си го свалите.Updated MP3 decoder to AE 4.8 - 16khz bug fixed.
Pentium III, k6 & Athlon optimizations.
New tag editor - integrated (click File Info).
PCM Equalizer - EQ ALL audio types (even CD & modules).
EQ load/save is complete (you can name your EQ presets now).
Full screen scaling (2:1, 4:1, 8:1).
WAV writer rewritten (again).
Visual system sped up a bit.
Spectrum 2 vis rewritten.
Fixed resource leak in cd audio player.
Fixed win95/98 sound & thread related bugs.
Lockup at end of song vanquished forever!
Windows 2000 Translucency (see settings).
Quintessential Player 3.20 БЕТА може да бъде свален с помощта на този линк.For CD audio, there is now per-drive volume mappings so you can set which volume control is for which CD. Just set, forget and crank it up without thinking about which drive to mess with!
For digital files, we've added streaming for all formats together with some additional killer streaming options, much better SHOUTcast support, and a 10 band EQ with presets and EQF support.
Now playlists with 1000's of tracks is faster, and QuickTrack is faster and more powerful than ever. And to add to these, you can now search through your playlist instantly, right on the player!
A note to long time QCD users: using the playlist has changed from the old style 'single click play'. The change was neccessary to add some more powerful features for playlist control. It may take some getting used to, but if I can do it so can you.
